enable igmp ssm-map
enable igmp ssm-map {vr vr-name}
Description
Enables IGMP SSM mapping on a VR.
Syntax Description
vr-name Specifies a virtual router name. If the VR name is omitted, the switch uses the VR specified by the current CLI VR context.
Default
Disabled on all interfaces.
Usage Guidelines
Configure the range of multicast addresses for PIM SSM before you enable IGMP SSM mapping. IGMP SSM mapping operates only with IPv4.
The following example enables IGMP-SSM mapping on the VR in the current CLI VR context:
enable igmp ssm-map
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IPv4 multicast feature, see the Switch Engine v33.1.1 Licensing Guide document.
